gvasuus
May 09, 2021Aspirant
Netgear Nighthawk Mesh - 1 satellite always goes down
One of the satillites gets disconnected and takes even couple of days to reconnect. Support team asked me to return and get a new one. I have done that twice and I still face the same issue. Ret...
- May 11, 2021
when you swap the c6900 to modem only, make sure to reboot the c6900 and the mk system. Also make sure only the mk router is connected to the c6900.
Putting the MK system into access point mode is pretty simple. Page 67 of the manual goes over that. Find the manual here:
May 09, 2021Guru - Experienced User
What mesh system do you have?
you're also using the c6900?
Has the router portion of the c6900 been disabled?
or the mesh system in access point mode?
How far from the main router is the satellite?
what are your interior walls made of?
gvasuus
May 10, 2021Aspirant
Nighthawk mesh wifi 6 system (AX1800 - MK63 / MK60 satillite)
Yes. C6900 is Modem router connected from ISP and MK63 is connected to C6900
No.
No
around 60-70 feet. Router is on 2nd floor and satellites are in 1st floor
Drywall
- plemansMay 10, 2021Guru - Experienced User
cascading routers is a recipe for network issues. its called double nat.
What is Double NAT? | Answer | NETGEAR Support
You can try the C6900 in modem only mode or put the MK router in access point mode.
- gvasuusMay 11, 2021Aspirant
I tried making the c6900 as modem only then, Nighthawk mesh MK63 was not recognized.
The connectivity is ISP connecting to C6900 (modem **bleep** router) and am connecting to MK63.
Advice me on how to setup MK63 as access point.
Thanks,
Vasudevan
- plemansMay 11, 2021Guru - Experienced User
