gvasuus's avatar
gvasuus
Netgear Nighthawk Mesh - 1 satellite always goes down
One of the satillites gets disconnected and takes even couple of days to reconnect.  Support team asked me to return and get a new one.  I have done that twice and I still face the same issue.   Ret...
  • plemans's avatar
    May 11, 2021
    when you swap the c6900 to modem only, make sure to reboot the c6900 and the mk system. Also make sure only the mk router is connected to the c6900.
    Putting the MK system into access point mode is pretty simple. Page 67 of the manual goes over that. Find the manual here:
    https://www.netgear.com/support/product/mk63.aspx
