TonYx870
Feb 03, 2022Aspirant
Netgear NIghthawk MK 62 AX1800 Mesh system Makes network slow
I have bought the router with 1 satellite combo and 1 additional satellite ..... After i connected the mesh system whole network speed went down as heck... ..we share our connection with 2 other fa...
Feb 04, 2022Guru - Experienced User
Yikes.
What is the distance between the router and 📡 satellite(s) and these 3 systems?
So what channels are the 3 different systems using on 2.4Ghz and 5Ghz?
Try ensuring each system is using different channels:
#1 set to channel 1 and 36
#2 set to channel 6 and 48
#3 set to channel 11 and 149
