Hcase1012
Dec 28, 2024Aspirant
NETGEAR Nighthawk MR 70
Hello- I’ve just installed my mesh system- I have Xfinity internet. I ended up just connecting my Xfinity router to the NETGEAR router using an Ethernet cord. But now I have two wi-fi networks, my ...
- Dec 29, 2024
That would do it.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dec 28, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
Hcase1012
Dec 29, 2024Aspirant
Thanks for the answer! I went ahead and put the Xfinity router in bridge mode, and now I only have one wi-fi network, and it’s the one NETGEAR is running.
It’s the Xfinity gateway, a newer one, I got it shipped to me about a month ago. Beyond that I don’t know much about it.
- FURRYe38Dec 29, 2024Guru - Experienced User
That would do it.
Enjoy. 📡
