clipod
Sep 21, 2022Aspirant
Netgear nighthawk MR60 access control doesnt work
Hi I am trying to enable access control to block certain devices. There are few devices that I am not aware of and I cant change password as its a pain to go through rest of my 40 devices for resetting my password. So I tried to enable access control and block unknown devices. My laptop is one of the allowed device. Once I enable access control, any website that I try to access is failing with a certificate issue. For example, when I clicked youtube.com, I am getting a certificate error because it shows that the certificate is from routerlogin.net
I gave up and tried revert back by disabling the AC, but everytime I tried to uncheck the box "Turn on Access Control" and click "Apply", it asks for router credentials and it reloads the page. I had to repeat close to 30 times and luckily on the final attempt, when I click "Apply", it stayed in the same page. Need help to block certain devices in my network without changing password.
What browser are you using? Try a different browser? MS Edge, Firefox or Opera?
- clipodAspirant
V1.1.6.124_2.0.59 is my firmware version. I tried to update if there are any newer releases but nothing showed up. I tried in Chrome, Safari. Also my other apps like slack, outlook etc threw a connection error.
Is there any other way to kick those devices out of my network?
It is such a sad experience from netgear to not have control on the devices that got connected with/without your knowledge.
Let me check into this...
