Retired_Member
Apr 05, 2021Netgear Nighthawk MR60 firmware version downgraded, now iOS app can see all of MS60 satellites
Since the middle of Feb after a firmware update on my MR60, the iOS app could not see any of my MS60 satellites. I reported this to Netgear support and they had me try everything including factory re...
Christian_R
Apr 09, 2021NETGEAR Employee Retired
Hello dturbo1,
Thanks for sharing your experience as it may possibly help others that may experience the same issue.
Christian
IainMurray
Apr 21, 2021Tutor
Christian
Clearly Netgear had a big problem with the 110 release and have now deleted it from support web site, I have also downgraded my system and I can now see 2 satelites on the IOS app. But when I look now at the app the decriptions of the connected devices are not nearly as easy to understand the descriptions are now poor. When will Negear provide the new firmware as we are having a bad experience with this product. Any firmware update should improve the product and fax issues not make things worse.
