jmurphy19199
Jun 11, 2020Aspirant
Netgear Nighthawk MR62 Wired Backhaul
Hi I have just purchased the Netgear MR62 Mesh System and having issues trying to get Wired Backhaul working. I currently have it now setup in traditional mesh mode with the satelite connecting wir...
Jun 11, 2020Guru - Experienced User
What switch are you using?
what modem are you using?
When you have it setup is it going like this:
modem-----to wan port on router------>router-------->lan port------->switch-------->satellites
i've seen people use modem/router combo devices and go like this
modem/router-------switch------->wan port on router
Satellites
- jmurphy19199Jun 11, 2020AspirantSo I have Ethernet jacks all over the house they al run back to a hp managed switch 2640. Modes/firewall is an acer.
How I imagined it could work would be
Modem/firewall to switch
Nighthawk router to switch
Satellite to switch
Is this not the case?- plemansJun 11, 2020Guru - Experienced User
Again, a lot depends on how you have it wired into the switch. and how the switch is setup.
There's some conversations on managed switches.
https://community.netgear.com/t5/Orbi/ORBI-and-Switch/td-p/1672848
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/td-p/1613897
you an also run into issues if the orbi is only connected to the switch via the WAN port.
It should go modem/firewall to wan port on orbi, then orbi connects lan port to switch with other devices connected to switch.
so to be clear.. the netgear nighthawk router needs a cable in the WAN port and the Ethernet port?
WAN port to my modem/firewall and Ethernet From the LAN to my Switch?
