tfox20445
May 13, 2023Tutor
Netgear tech support for MR-60
Having an issue with my MR-60 mesh router and can't get any Netgear tech support. Only 90 days of support - you've got to be kidding me. Thinking of returning this router to Costco.
tfox20445
May 13, 2023Tutor
Here is my issue: My MR60 mesh router is causing an issue with my Epson AIO: The printer cannot "see" my desktop computer, so I can't use the control panel on the printer to do my scans. It seems to be "caused" by the MR 60 router. When I switched back to my Netgear AC1750 router, the issue disappeared. Any ideas on how to "fix" my MR 60 system? I need the mesh system in my new house.
Note that I didn't do anything special on my old router and the Epson could see my desktop computer.
May 13, 2023Guru - Experienced User
When you switched networks, did you go into your windows installation and set the new network as private?
Whenever you switch networks, it defaults to public network settings for protection.
- tfox20445May 13, 2023Tutor
My network is private.
- michaelkenwardMay 13, 2023Guru - Experienced User
Did you take your unnamed Epson printer/scanner through the same setup process that you did when you installed it on whatever model the AC1750 router was? (Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.)
You don't say how you connect the Epson to the network. (As plemans says, the devil is in the detail.) Wifi? LAN? USB?
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
