Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
Nov 13, 2021Guru - Experienced User
Try a factory reset and setup from scratch...
steveof2620
Nov 13, 2021Star
Awesome, thanks.
I go to Advanced / Backup Settings. I click Erase under the "Revert to factory default settings", click Yes under "Are you sure you want to do this?
The system reboots and comes back with all its settings intact. What is the story here?
- FURRYe38Nov 14, 2021Guru - Experienced User
What browser are you using?
Be sure to clear out all browser caches after selecting ERASE and YES then clear caches and exit or close browser. Then reopen.
What happens if you press the reset button in back for 15 seconds?
steveof2620 wrote:
Awesome, thanks.
- guitarman3001Nov 21, 2021Star
This firmware seems to have broken my system. It was already not working properly before.
After updating I now have a few new problems.
1. From the Nighthawk app, both satellites show No Connected device found. I know this is not accurate because when I go to the web interface of each satellite and the router I see several devices attached to both satellites and the router. WTF?
2. The Nighthawk app shows almost every device attached directly to the router by WIRED connection. Again, WTF?
Can Netgear do anything right? I've had more problems than I can count with this system since day one of getting it back in April.
Netgear, if you're listening, this POS is less than a year old. What can you do to make it work? Like I mentioned, I've had issues since day one. Speed limited to 80mbps, devices not connecting to each other (Roku app losing connection with Roku devices, unable to RDP from laptop to desktop, etc.. and I know the devices are connected to the access points, the router/satellite just stops routing traffic between devices), I've opened support cases and nothing has been fixed.
Can you just replace this horrible system with something that might actually work like it's supposed to?
- guitarman3001Nov 22, 2021Star
BTW, I had to update the firmware manually because every time I tried through the app it gave me an error and when I tried automatically via the router's web interface it would show "service unnreachable." Ridiculous.
If I hadn't thrown out the box I'd return it to Costco and replace it with one of the Google mesh systems. They don't have as many bells and whistles but they just work. And what good are bells and whistles when the entire system is junk?
