Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
jomonugget
Nov 27, 2021Aspirant
Question, for some reason attempting to update the firmware, when I clicked on check for new version on the internet (of firmware), it would not detect the new version. I managed to update it manually, but something was preventing it from reaching out to the update servers I believe. After the update to firmware 1.1.6.122 was completed , I attempted to "check for new version on the internet" , which obviously I know there's not, but instead of getting the usual "You have the latest version installed, I'm getting a "Service Unreacheable". The 192./debug.htm page has the following info which I'm wondering if I should edit:
ftp server: updates1.netgear.com
https server:http.fw.updates1.netgear.com
thanks for the help.
Nov 28, 2021Guru - Experienced User
- jomonuggetNov 28, 2021Aspirant
It's connected to Century Links Fiber to Home 1Gb service, Adtran Total Access 352 1287702G1.
- FURRYe38Dec 08, 2021Guru - Experienced User
Well theres no router at the ONT so there shouldn't be a problem there.
You don't need to edit the update services URLs. Those are default for everyone.
Possible there maybe an outage with NG services. We have seen this before.
