Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
Jan 09, 2022Guru - Experienced User
Yes any factory reset will clear out any user configurations and user set passwords. It does not change the FW version. Just clears out user configurations.
Naairda
Jan 10, 2022Aspirant
FURRYe38 wrote:Yes any factory reset will clear out any user configurations and user set passwords. It does not change the FW version. Just clears out user configurations.
I thought it odd that installing a different FW apparently also changes the 'factory username and password'.
- FURRYe38Jan 10, 2022Guru - Experienced User
Ya thats odd, FW updates shouldn't do that....
