Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
R0fflez
Jan 23, 2022Aspirant
I just wanted to add that im also having the same problems right after the update to FW 1.1.6.122. I will list the issues just to see if anyone else is experiencing the exact and/or similar issues:
- Unstable connection with a drastic speed drop
- MR60 Router does not see (will not sync) with the satellite
- Any type of speedtest fails
- Something ive noticed and not sure if it would be an issue with anything is that ive noticed that the router has always had issues with connecting to the NTP server. Please let me know if this would be an issue.
Issues within the APP:
- App shows that the satellite is connected but satellite (MS60) LED is amber
- App shows all devices connected to router is a wired conection when there is no wired devices connected
- App shows a picture of a completely different device in the network map. (It actually shows me a picture of the R7500 and not the MS60)
There are other issues that are happening but these are the big problems ive discovered. If anyone has anymore issues other than what i listed please feel free to let me know so i can check my system. Ive started a ticket with netgear but it seems like all thats happening is a lot of questions and waiting for responses which is not helping.
Jan 24, 2022Guru - Experienced User
Try reverting back to v116?
- NaairdaJan 27, 2022Aspirant
Well, I am not very smart. I left auto-update on and it installed the latest malfunctioning 1.1.6.122 last night. Same problems: sattelites missing, new IP addresses becasue they had diferent MAC adressses again (6th octet), etc.. Fortunately, I know how to go back now and have turned off auto-update.
- pieintheskyJan 27, 2022GuideI’m generally curious if anyone has a response from Netgear? Or if there is anyone “official” from Netgear on these forums.
They closed my case saying “Firmware is operating within specification” how the f*** can all these bugs people are reporting and multiple people having the same issue “Within Spec”.
Netgear is a f***ing joke!- NaairdaJan 27, 2022Aspirant
<snip>I am also not impressed with how this is being handled. I fail to understand why the firmware is working for some people as it does some seriously wacky things (MAC-adress change? Seriously?). Could it be that people reporting problems here have different hardware versions (as in a different spec/iteration) than others?
