Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
Feb 07, 2022Guru - Experienced User
- NaairdaFeb 07, 2022Aspirant
FURRYe38 Are you referring to the bricking or the speedtest?
- Nothing bricked for me fortunately.
- I never tested the speed when 1.1.6.122 was installed. Did a speedtest now using the nighthawk app. It worked, but this is FW 116 I'm on. NOT about to install 122 again.
- FURRYe38Feb 07, 2022Guru - Experienced User
Thanks for your information.
- R0fflezFeb 08, 2022AspirantTo respond about the bricking. My router and satellite did not brick per say. After reverting back to the prior firmware, i do however notice that the satellite falls out of sync now. Connection between satellite and router isn't as good anymore. Internet speeds are inconsistent but not sure if it was due to something in the firmware.
- FURRYe38Feb 08, 2022Guru - Experienced User
Did you down grade both MS and MR back to v116 then factory reset and setup from scratch?
