Nov 12, 2021Guru - Experienced User
New - MK6x series: MR60 / MS60 FW v1.1.6.122 Released
New Features and Enhancements: 11/11/2021
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed...
Naairda
Feb 07, 2022Aspirant
FURRYe38 Are you referring to the bricking or the speedtest?
- Nothing bricked for me fortunately.
- I never tested the speed when 1.1.6.122 was installed. Did a speedtest now using the nighthawk app. It worked, but this is FW 116 I'm on. NOT about to install 122 again.
Feb 07, 2022Guru - Experienced User
Thanks for your information.
