Nov 30, 2021Guru - Experienced User
New - MK8x series: MR80 / MS80 FW v1.1.6.10 Released
Security Fixes: 11/29/2021
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
MR80 (Mesh R...
azieba
Dec 02, 2021Aspirant
Can someone check the download files?
Can't seem to upgrade it. Tells me the file is not compatible. I have tried downloading multiple times to ensure it was not corrupt. I have MK83 setup with MR80 and MS80. When I manually upgrade the MS80s I get the following error:
Failure |
| This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. |
| This screen will automatically return to the previous screen in a few seconds... |
- FURRYe38Dec 02, 2021Guru - Experienced User
What broswer are you using? Try MS Edge or Firefox?
I presume you are unpacking the .zip files as well?
FailureThis firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. This screen will automatically return to the previous screen in a few seconds... .
