Nov 30, 2021Guru - Experienced User
New - MK8x series: MR80 / MS80 FW v1.1.6.10 Released
Security Fixes: 11/29/2021
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
MR80 (Mesh R...
azieba
Dec 02, 2021Aspirant
Can someone check the download files?
Can't seem to upgrade it. Tells me the file is not compatible. I have tried downloading multiple times to ensure it was not corrupt. I have MK83 setup with MR80 and MS80. When I manually upgrade the MS80s I get the following error:
Failure |
| This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. |
| This screen will automatically return to the previous screen in a few seconds... |
Dec 02, 2021Guru - Experienced User
What broswer are you using? Try MS Edge or Firefox?
I presume you are unpacking the .zip files as well?
Failure
This screen will automatically return to the previous screen in a few seconds... .
