Nov 30, 2021Guru - Experienced User
New - MK8x series: MR80 / MS80 FW v1.1.6.10 Released
Security Fixes: 11/29/2021
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
MR80 (Mesh R...
Dec 02, 2021Guru - Experienced User
What broswer are you using? Try MS Edge or Firefox?
I presume you are unpacking the .zip files as well?
azieba wrote:
Can someone check the download files?
Can't seem to upgrade it. Tells me the file is not compatible. I have tried downloading multiple times to ensure it was not corrupt. I have MK83 setup with MR80 and MS80. When I manually upgrade the MS80s I get the following error:
Failure
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
This screen will automatically return to the previous screen in a few seconds... .
azieba
Dec 02, 2021Aspirant
Unzipped and selected the .chk file. I used Firefox but I will try MS Esge
- aziebaDec 02, 2021Aspirant
I tried Firefox, Edge and Chrome. All three fail with the same error.
Open to other ideas.
- FURRYe38Dec 02, 2021Guru - Experienced User
And you do have the MK80 series system correct?
What version of FW is currently loaded?
- aziebaDec 02, 2021AspirantCorrect 2 MS80s tied to an MR80, all three are running v1.1.6.6.
