Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
DeveshNatalia
May 14, 2022Aspirant
Is this firmware safe to use across the router and satellites?
May 14, 2022Guru - Experienced User
Your supposed to use any FW version across both MR and MS. Both MR and MS need to be on same version of FW. Update the MS first, then MR lastly.
- DeveshNataliaMay 15, 2022Aspirant
MR and MS are now all on the same version 1.1.6.124 but am getting intermittent timeouts and high latency, this was never a problem two weeks ago and the problem is noticeable on a voice and /or video call. Is the firmware the issue?
- Hettick123May 22, 2022AspirantSame!
- DeveshNataliaMay 22, 2022AspirantI have since upgraded all of the satellites and router to the latest firmware and all appears to be Ok since Monday.
