Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
mac_man
May 23, 2022Aspirant
I would steer clear of this firmware version. I updated from 1.1.6.122 and have had multiple devices refuse to reconnect and some drop regularly from HomeKit. Anyone else experience this?
I'll be working on downgrading if possible ASAP.
- gbh3May 23, 2022Initiate
I'm not seeing any issues since updating to "124".
- DeveshNataliaMay 23, 2022Aspirant
I upgraded to .124 about 1 weeks ago. About 1 hour after upgrading it started misbehaving where there was high latency and the satellites dropped off a couple of time for a brief moment but for the last 7 days I have to say it has been stable. My wife and I are continuously on video and voice calls and have found the connection to be a lot more stable.
- FURRYe38May 23, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.I would also try a factory reset and setup from scratch as well.
