Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
mac_man
May 23, 2022Aspirant
I would steer clear of this firmware version. I updated from 1.1.6.122 and have had multiple devices refuse to reconnect and some drop regularly from HomeKit. Anyone else experience this?
I'll be working on downgrading if possible ASAP.
May 23, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I would also try a factory reset and setup from scratch as well.
