Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
Mschambe
Aug 15, 2022Aspirant
Can someone explain where Advanced is and why when I check for updates on my MR60 it always comes back - No new firmware available. But my firmware version is : v1.1.6.122 and under security it shows vulnerabilities for the router and two satellites with device update highly recommended. There is no Advanced available on the BASIC home page where I can navigate and update manually.
- FURRYe38Aug 15, 2022Guru - Experienced User
What browser are you using? Try MS Edge, FireFox or Opera with the MRs web page.
Following the manual updating process in this thread.
Be sure to update the MS first then the MR lastly.
- MschambeAug 15, 2022Aspirant
I am using the Nighthawk app on both an iPad and android phone. I can Device manager, security, internet speed, Wi-Fi analytics, etc but nothing for advanced. I can click to access menu options - settings - router settings and click on check for updates. Looked all over for Advanced to update manually.
Follow the manual updating process in this thread.
