Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
Mschambe
Aug 15, 2022Aspirant
I can log out and then back in using my credentials via the Knighthawk app. When I open a web page in edge or chrome on windows or Firefox in Linux, got router login.net and enter those same credentials, all three browsers behave the same. no error message, they just clear out the username and password fields. I never experienced this before, I was hoping I could login this way and see the Advanced tab referenced in the MR60 user manual.
Aug 15, 2022Guru - Experienced User
Can you try a windows or mac PC by chance?
