Apr 27, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.6.124 Released
New Features and Enhancements: 04/27/2022
Supports Smart Parental Controls (SPC)
Fixed AirPlay issue while iPhone/iPad and Apple TV are connected to the same node, either MR60 or MS60.
Fixed ...
Aug 18, 2022Guru - Experienced User
So admin and password don't work to get into the MS web page?
Are they showing synced with the MR on the MRs web page?
The MS need to be updated before the MR is.
NG may not be pushing or giving notifications of new FW on there systems. So giving users a bit more control of FW updates, users can review NGs download site or the forum for FW update information and manually update FW on there own.
kickns
Aug 18, 2022Aspirant
Yes, both satellites show a good status on the MR's web page and on the Nighthawk app.
I understand the the MS needs to be updated before the MR. Any workarounds available for the password situation? Or do I have to perform a factory reset on each satellite? If I do that, do I need to connect my laptop to the MS via Ethernet to upload the new firmware? And then can I use the Nighthawk app to reconnect the MS to the MR? I guess I am asking if this is the sequence:
1. Factory reset first MS and then upload new firmware then power down
2. Factory reset second MS and then upload new firmware then power down
3. Upload new firmware to MR; power off for two minutes than power up
4. Pray that MR comes up then use Nighthawk app to reconnect MSes
Anything missing? Where are the possibilities for bricking the system?
Thanks
