Oct 17, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.7.132 Released
New Features and Enhancements: 10/17/2022
Fixed Armor might be deactivated issue after FW update.
Fixed SPC doesn’t work after users block devices in Access Control.
Support Xunyou service in...
Tagoren06
Oct 17, 2022Aspirant
After new firmware was installed overnight. WIFI is not allowing some devices to connect. In the admin panel, it is showing a few devices are online but will not allow others to connect. I have rebooted, removed the power for 2+ min, etc still nothing. Was working just fine late last night.(Oct 16). I have not yet tried a factory reboot as all my wired connections are working just fine. Frustrating that due to firmware my network goes down and I might have to pay for support for an issue that was caused but the device.
dihy
Getting the same problems here, my WiFi has been going up and down all day, hard wired OK.
Already tried restarting units after powering down, still getting the wifi issue.
- FURRYe38Oct 17, 2022Guru - Experienced User
I would try a full on factory reset and setup from scratch.
Can you both confirm that the MS go the same version FW update as well as the MR did?
- dihyOct 17, 2022Aspirant
All units are on 1.1.7.132, I had to factory reset the devices to get them to reconnect, then restarted the satellites again to get them to connect to the main.
- DCieslinskiNov 16, 2022Guide
Same with mine. I had to revert the firmware back to v1.1.6.xxx
