Oct 17, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.7.132 Released
New Features and Enhancements: 10/17/2022
Fixed Armor might be deactivated issue after FW update.
Fixed SPC doesn’t work after users block devices in Access Control.
Support Xunyou service in...
dihy
Oct 17, 2022Aspirant
Getting the same problems here, my WiFi has been going up and down all day, hard wired OK.
Already tried restarting units after powering down, still getting the wifi issue.
I would try a full on factory reset and setup from scratch.
- FURRYe38Oct 17, 2022Guru - Experienced User
Can you both confirm that the MS go the same version FW update as well as the MR did?
- dihyOct 17, 2022Aspirant
All units are on 1.1.7.132, I had to factory reset the devices to get them to reconnect, then restarted the satellites again to get them to connect to the main.
Ok, so your system is back up and running again after a FR and your devices are all connected again?
