Oct 17, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.7.132 Released
New Features and Enhancements: 10/17/2022
Fixed Armor might be deactivated issue after FW update.
Fixed SPC doesn’t work after users block devices in Access Control.
Support Xunyou service in...
Can you both confirm that the MS go the same version FW update as well as the MR did?
dihy
Oct 17, 2022Aspirant
All units are on 1.1.7.132, I had to factory reset the devices to get them to reconnect, then restarted the satellites again to get them to connect to the main.
- FURRYe38Oct 17, 2022Guru - Experienced User
Ok, so your system is back up and running again after a FR and your devices are all connected again?
- dihyOct 17, 2022Aspirant
Took about an hour of redoing settings to get the network up.
This is very garbage behavior of netgear tbh, pushing the firmware update without notification and killing user networks. I was in the middle of a work meeting and everything started going haywire.
Ok, thanks for letting us know.
Is there a check box for disabling or enabling FW updates on the MRs web page under Advanced tab/Admin? If there is, might uncheck this.Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
