Oct 17, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.7.132 Released
New Features and Enhancements: 10/17/2022
Fixed Armor might be deactivated issue after FW update.
Fixed SPC doesn’t work after users block devices in Access Control.
Support Xunyou service in...
Tagoren06
Oct 17, 2022Aspirant
After new firmware was installed overnight. WIFI is not allowing some devices to connect. In the admin panel, it is showing a few devices are online but will not allow others to connect. I have rebooted, removed the power for 2+ min, etc still nothing. Was working just fine late last night.(Oct 16). I have not yet tried a factory reboot as all my wired connections are working just fine. Frustrating that due to firmware my network goes down and I might have to pay for support for an issue that was caused but the device.
dihy
Oct 19, 2022Aspirant
Do a factory reset.
- FURRYe38Oct 19, 2022Guru - Experienced User
Lets get the ISP services stable first before doing a reset. Possible his issues are not related to what you saw on yours.
I've got mine hooked up but the system isn't seeing any FW updates from NG. Im waiting on some feedback on this.
- FURRYe38Oct 23, 2022Guru - Experienced User
I manually loaded FW on my 60 series since new FW was not being seen in the AU section, then powered OFF for 1 minute then back ON. System has been up and running fine. No factory resets.
- FURRYe38Nov 16, 2022Guru - Experienced User
- FURRYe38Nov 19, 2022Guru - Experienced User
Put my MK63 online in AP mode with v.132 loaded. Working 1+ days up time:
All 32 devices are connected.
