Oct 17, 2022Guru - Experienced User
New - MR60 / MS60 Firmware Version 1.1.7.132 Released
New Features and Enhancements: 10/17/2022
Fixed Armor might be deactivated issue after FW update.
Fixed SPC doesn’t work after users block devices in Access Control.
Support Xunyou service in...
Oct 19, 2022Guru - Experienced User
Lets get the ISP services stable first before doing a reset. Possible his issues are not related to what you saw on yours.
I've got mine hooked up but the system isn't seeing any FW updates from NG. Im waiting on some feedback on this.
Oct 23, 2022Guru - Experienced User
I manually loaded FW on my 60 series since new FW was not being seen in the AU section, then powered OFF for 1 minute then back ON. System has been up and running fine. No factory resets.
