Jan 05, 2023Guru - Experienced User
New - MR70 / MS70 Firmware Version 1.0.3.32 Released
New Features and Enhancements: 12/23/2022
- Fixed security issues.
- Support Smart Parental Control service.
- Fixed WiFi connectivity and stability issue.
- Fixed APP installation might not work smoothly if MR70 detected WAN/LAN IP conflict.
Download Link:
https://www.netgear.com/support/product/mk72.aspx#download
Installation Instructions:
- Download the firmware to a convenient place such as your desktop.
- Log in to the router using http://routerlogin.net
- Click the ADVANCED tab.
- Click Administration.
- Click Router Update.
- Click the Manual Update tab.
- Select satellite first and a new web page pops up. Please browse the new satellite firmware and upgrade satellite firmware first.
- After you finish the satellite firmware upgrade, please find “Locate and select the upgrade file on your disk” on the MR60 web GUI and click “Browse” and locate the file you just downloaded.
- Click Upload. While the firmware is loading, do not interrupt the upgrade process.
- The router reboots when the upgrade is complete. After the router boots up and the LED becomes steady blue.
To check that the upgrade was successful, log in to the router again at http://routerlogin.net and check the firmware version.
If you manually update, be sure to update the MS first, then MR lastly.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Update the MS first, then the MR lastly. After the FW files are loaded and the MS and MR are ready, power OFF the MS and MR for 2 minutes then back ON.
Unplug the power adapters from the power wall outlet.
NOTE: A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you. Please leave feed back in this thread.
1 Reply
