Jan 03, 2023Guru - Experienced User
New - MR80 / MS80 Firmware Version 1.1.7.14 Released
Security Fixes: 12/22/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Bug Fixes:
Fixes the i...
rush12
Feb 05, 2023Aspirant
Hi, having issues updating to this firmware. I currently just have the router and 1 satellite setup. Logged into router and checked for Online updates. On V1.1.7.12 and get "No new Firmware available" message. I then try to manually update with the new download, and when I go to update the satellite first, I get prompted for a login, enter router login info and then I get a 404 not found for the upgrade_page. http://10.0.0.4/start.htm?page=upgrade_page Any help on this issue and being able to get the satellite updated first?? I have Rebooted the router but no reset.
Firmware: V1.1.7.12_3.1.108
GUI: V1.1.7.12_2.1.46.1
Thanks
- FURRYe38Feb 05, 2023Guru - Experienced User
So can you access the MS web page directly using it's IP address in a web browser seen on the MRs web page?
Seems like you have a host router infront of the MR?
- rush12Feb 27, 2023Aspirant
"So can you access the MS web page directly using it's IP address in a web browser seen on the MRs web page?"
Yes it seems so, this is where I get redirected under Advanced>Adminstration>Router Update>Manual Update (tab) > then I get a table with a list of MS satellites connected. To update Netgear satellite , select the device then click the update field to continue> selecting a connected Satellite navigates me to the URL I listed previously. Prompts me to login, but no matter what I do I am unable to login.
"Seems like you have a host router infront of the MR?What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?"
I have a Verzion 5G Internet Gateway/ WIFI 6 router (ARC-XCI55AX) set to IP passthrough mode. From Verizon website - "Enabling IP passthrough causes the IP address assigned by the network to hand off to the device connected to the LAN2 port" This is all true. The NG routers works as intended and obtains the public IP, etc. I wouldnt think the Gateway's network/subnet would matter in passthrough mode, but maybe it does. It would still be set to 192.168.1.1.
Any ideas?
Thanks
- FURRYe38Feb 27, 2023Guru - Experienced User
What is the IP address the MR is getting from the ISP modem on it's WAN port? Is it a ##.##.###.### address or a 10.something address?
What you might do is to download the MS and MR FW files to a wired PC, disconnect the MR from the ISP modem. Factory reset the MR and MS and get them up and running. You don't have to have the MR connected to the ISP modem. Use a wired PC to walk thru the set up wizard at 192.168.1.1. The MS should connect. Log in to the MS web page using the IP address seen on the MR for the MS. Load the MS FW file here on the MS web page. Then send the MRs FW file to the MR. After all has been sent and processed and the MS and MR is back to ready. Power OFF the MS and MR. Reconnect the MR to the ISP modem, then power ON the MR and MS. Might power cycle the ISP modem off for 30 seconds then back ON as well.
