Jan 03, 2023Guru - Experienced User
New - MR80 / MS80 Firmware Version 1.1.7.14 Released
Security Fixes: 12/22/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Bug Fixes:
Fixes the i...
Feb 05, 2023Guru - Experienced User
So can you access the MS web page directly using it's IP address in a web browser seen on the MRs web page?
Seems like you have a host router infront of the MR?
rush12
Feb 27, 2023Aspirant
"So can you access the MS web page directly using it's IP address in a web browser seen on the MRs web page?"
Yes it seems so, this is where I get redirected under Advanced>Adminstration>Router Update>Manual Update (tab) > then I get a table with a list of MS satellites connected. To update Netgear satellite , select the device then click the update field to continue
> selecting a connected Satellite navigates me to the URL I listed previously. Prompts me to login, but no matter what I do I am unable to login.
"Seems like you have a host router infront of the MR?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?"
I have a Verzion 5G Internet Gateway/ WIFI 6 router (ARC-XCI55AX) set to IP passthrough mode. From Verizon website - "Enabling IP passthrough causes the IP address assigned by the network to hand off to the device connected to the LAN2 port" This is all true. The NG routers works as intended and obtains the public IP, etc. I wouldnt think the Gateway's network/subnet would matter in passthrough mode, but maybe it does. It would still be set to 192.168.1.1.
Any ideas?
Thanks
- FURRYe38Feb 27, 2023Guru - Experienced User
What is the IP address the MR is getting from the ISP modem on it's WAN port? Is it a ##.##.###.### address or a 10.something address?
What you might do is to download the MS and MR FW files to a wired PC, disconnect the MR from the ISP modem. Factory reset the MR and MS and get them up and running. You don't have to have the MR connected to the ISP modem. Use a wired PC to walk thru the set up wizard at 192.168.1.1. The MS should connect. Log in to the MS web page using the IP address seen on the MR for the MS. Load the MS FW file here on the MS web page. Then send the MRs FW file to the MR. After all has been sent and processed and the MS and MR is back to ready. Power OFF the MS and MR. Reconnect the MR to the ISP modem, then power ON the MR and MS. Might power cycle the ISP modem off for 30 seconds then back ON as well.
- rush12Feb 27, 2023Aspirant
On Internet Setup we are getting the Internet IP Address dynamically from ISP. Its a 7x.XXX.XXX.XX ip.
On the WAN Setup config page, these are the current settings[] (unchecked) Disable Port Scan and DoS Protection
[] (unchecked) Default DMZ Server - IP 10.0.0.0
[] (unchecked) Respond to Ping on Internet Port
[] (unchecked) Disable IGMP Proxying
MTU Size 1500 bytes
NAT Filtering - Secured
Good thing is I already have the firmware downloaded locally for the manual update. Sounds like I may have to try disconnecting from ISP and trying to update and/or doing a reset on the MR and MS and then trying to update on wired connection disconnected from the ISP.
Thanks
