Razor512
Jan 23, 2024Prodigy
New - MR90 / MS90 Firmware Version 1.0.2.38 Released
New Features and Enhancements: 01/23/2024
Support APS HK region.
Support Router Protection feature.
Security enhancement.
NOTE: A new feature maybe seen in this version of FW, Protec...
michaelkenward
Jan 24, 2024Guru - Experienced User
Thanks for that.
Too soon for the update to show up on the internal GUI check. So went and did a manual run. Took time.
After the router update satellites did not show up on the Router Update page. But they were there in Attached Devices so I could get in with the IP address.
They are here now. Perhaps it needed more time or compatible firmware.
Updates went through with no problems, albeit slow.
No visible after effects.
Following the link to the KnowledgeBase piece on Protection Engine, I had to look hard to find the Protection Engine Version. Its is on 2.2.193/1.0.0.2053
The link in Advanced >> Security to Protection Engine says nothing about version numbers. Might be worth having the version there too.
PS The MK9# stuff is not there in the Associated Products slot.
- FURRYe38Jan 27, 2024Guru - Experienced User
Manually updated my MK93 system.
Looking good. Even with a BE200 PCI card:
