Ceerob
Jun 28, 2022Follower
New modem, same mesh
I need to change my modem. Will I have to change all of my mesh settings or can I just plug the Nighthawk MK6W into the new modem, keeping all of my cameras, TVs, thermostats connected? I am doing thi...
Jun 28, 2022Guru - Experienced User
It should be pretty plug and play.
get the modem activated.
then follow the guide FURRYe38 wrote on connecting the router.
I've rarely needed to do a factory reset on my router after changing modems. Its happened but usually if I'm also changing speed tiers.
