nedgoon222
Jan 04, 2022Aspirant
New Nighthawk AX1800 MK63 Mesh WiFi 6 System dropouts and connection problems
1st question: Moderator. Why is my model number not in the drop down list? 2nd Question: We currently have the bog standard NBN router supplied by Telstra. It barely covers my wife's separate...
Jan 05, 2022Guru - Experienced User
1st questions.---you're not in the proper forum for your device. Could be why its not on the list.
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
2nd question. Its more complex.
A. what telstra gateway is it? The modem/router combo devices cause a double nat which can cause issues.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
This could be whats causing the periodic crops or issues with the app.
B. 35m and 40m is quite a bit of range. I'm pretty impressed the telstra is making it that far and that the netgear is as well. Exterior (as your post implies with 'seperate') walls do a great job of blocking wifi because they tend to be made from materials that are great at blocking wifi. Like metal siding, brick, concrete, have foil lined insulation, cement board, etc. So I'm a bit impressed it makes it that far through exterior walls. Any chance you have ethernet ran between the buildings? Or coax (could use a moca adapter)? If you can find a way to use the hardwired backhaul between router/satellites, you'll have much faster and more stable speeds.
