Nwagtmustang's avatar
Nwagtmustang
Follower
Nov 21, 2020
Nighhawk mesh wifi 6 some devices cant connect
I purchased netgear nighthawk mesh wifi 6. I wanted my pc to use wifi 6. In order to use wifi 6 wpa 3 needs to be used. When I enable wpa3 my Samsung TV and roku can not connect to the router. My next idea was to create a 2.4 ghz network using WPA 2 and 5ghz using WPA 3. Have pc on 5ghz and other devices on 2.4. This router does not give me this option.
I thought wifi 6 is supposed to be backward compatible. I dont understand why when using WPA 3 my roku and TV will not connect? Whats the point of having wifi 6 if older devices can not connect to it? So I went back to using WPA 2 on all devices. I read in order for a pc to use wifi 6, WPA 3 needs to be enabled? Is that correct? I go into network adapter settings and see ax protocol. I select it but reverts back to wifi 5.
Is there something I'm missing?
  • Nignthawk Mesh MR60 and MS 60 satelites.
    I have a similar issue. I need my streaming Apple TV to use 5ghz which is assigned to channel 36 so as to not saturate channel 8 and cause TV spooling. How do I do this?
    I also want to define which fixed device connects to a fixed satelite so as to not over use a satelite and hurt speed. How do I do this?
  • schumaku's avatar
    schumaku
    Nwagtmustang WPA3-Personal is mandatory for the certification of WiFi 6 since mid 2020. It's not mandatory to operate WiFi 6 however.
    WiFi 6 is backward compatible - well, mostly. Not all clients are due to bugs, shortcomings, or lack of maintenance!).
    More cumbersome is WPA3. If you configure the Nightawk Mesh to WPA3-Personal this is _only_ allowing the association of WPA3-capable devices - your Sammy or the Roku are most likely not WPA3-enabled, so they can't associate. The cumbersome point is that many - far to many popular ones - wireless clients have issues with the wireless association when WPA2-Personal & WPA2-PSK/AES. This is why the vendors avoid making this mixed-mode available on their access points these days. This is probably the missing point here.
    No idea what network adapter properties you are looking into. On the Intel AX200 and a decent Windows 10, the adapter properties control "802.11n/ac/ax Wireless Mode" does define the highest mode available. When you select 802.11ac, the adapter can make 802.11n or 802.11ac - but no 802.11ax. Note that 802.11ax applies to the 2.4 and 5 GHz band.
    WiFi 6 and Mesh does act best with both 2.4 and 5 GHz radios available on the same SSIDs.
