Chainsaw801
Nov 22, 2022Aspirant
Night Hawk MR60 Slow WiFi
Very frustrated with this system. I have browsed through the forums and nothing seems to help. Firmware is V1.1.7.132_2.0.64. I have a Arris SB6190 cable modem through Xfinity. Wired from the MR6...
Jan 03, 2023Guru - Experienced User
Would be good to know if newer FW resolves this or not:
- Chainsaw801Jan 03, 2023Aspirant
I'd like to hope so. I can't even upgrade the devices manually. I get a 404 Not Found error after I enter my credentials. When I try to let the software search it doesn't give me the option of new firmware.
- FURRYe38Jan 03, 2023Guru - Experienced User
So can you try manually updating the MS first then MR lastly as described in the link given?
You can log in to the MS web page and send the extracted .zip FW file on the MS web page using a PC and web browser.
That's the problem. I can't log into the MS. When I click manual update and click on the MS, it launches a new window to prompt for my credentials. I input the creds and it accepts them then goes to a 404 error.
http://192.168.137.2/start.htm?page=upgrade_page
