Chainsaw801
Nov 22, 2022Aspirant
Night Hawk MR60 Slow WiFi
Very frustrated with this system. I have browsed through the forums and nothing seems to help. Firmware is V1.1.7.132_2.0.64. I have a Arris SB6190 cable modem through Xfinity. Wired from the MR6...
Chainsaw801
Jan 03, 2023Aspirant
That's the problem. I can't log into the MS. When I click manual update and click on the MS, it launches a new window to prompt for my credentials. I input the creds and it accepts them then goes to a 404 error.
http://192.168.137.2/start.htm?page=upgrade_page
Jan 03, 2023Guru - Experienced User
Is that the IP address seen on the MRs web page under Basic/Connected Devices for the MS?
Is try just the IP address alone 192.168.137.2
Just curious is the MS using 192.168.137.1 as it's IP address and spool string? Normally it should be 192.168.1.1 or .0.1...
- Chainsaw801Jan 03, 2023Aspirant
Yes the address is correct. I'm being prompted for the login credentials when I click on the address from the upgrade page. I have set a static reservation for each of the devices. I have tried using the following URLs all with the same 404. I have even tried plug in my ethernet cable directly into the back of one of the MS units.
.1 is the MR60
.2 is one MS
.3 another MS
Okay, I got it working to where I can update. I forced a password change on the main unit and now I am able to log in. Weird.
I will update the firmware on all three units and post my findings. I think it's important to keep these threads updated in case someone else runs into the same problems.- FURRYe38Jan 03, 2023Guru - Experienced User
Be sure to update the MS first the MR lastly. Try a full power OFF of the MR and MS for 1 minute then back ON afterwards.
