Chainsaw801
Nov 22, 2022Aspirant
Night Hawk MR60 Slow WiFi
Very frustrated with this system. I have browsed through the forums and nothing seems to help. Firmware is V1.1.7.132_2.0.64. I have a Arris SB6190 cable modem through Xfinity. Wired from the MR6...
Jan 03, 2023Guru - Experienced User
Try speed testing with the MS turned off to check of the PC is getting what it should at the MR. I wish there was power controls on the MR. Would be helpful to reduce the power some.
