Curran6150's avatar
Curran6150
Nighthawk AD7200 x10 Quad Stream MU-MIMO-AC and NIGHTHAWK MESH WIFI 6 ADD-ON SATELLITE (MK63)
I have a Nighthawk AD7200 set up at my location, but the signal is weak at the extremities of the house. I see that the
NIGHTHAWK® MESH WIFI 6 SYSTEM (MK63) can cover 4000 foot, but as I already have a really decent router could I use the two satelites to place either end of my house to extend the range. Will they easily set up to my current router without too much effort and will they appear on my netgear app so that I can update the software when required?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Curran6150,
    You may use the MK63 system in access point mode for it to be compatible with your existing Nighthawk router.
    Christian
