maxbuffington
Jul 03, 2022Initiate
Nighthawk and MR80 Router
I have a Nighthawk MR 80 Router and 2 MS 80 Satellites. The system has been operating fine for about 11 months. Recently I have begun to receive "router not found" error message on Nighthawk app ru...
Jul 04, 2022Guru - Experienced User
If you're on iOS/mac, make sure that icloud relay and private mac/ip address are disabled.
- maxbuffingtonJul 04, 2022Initiate
Your recommendation worked!!!
I’m using iOS 15.5 for my iPhone and iPad.
Thanks!
- plemansJul 05, 2022Guru - Experienced User
Glad it did!
If you mark it solved it might help the next person with the issue as well as it prevents others from trying to fix it
