maxbuffington
Jul 03, 2022Initiate
Nighthawk and MR80 Router
I have a Nighthawk MR 80 Router and 2 MS 80 Satellites. The system has been operating fine for about 11 months. Recently I have begun to receive "router not found" error message on Nighthawk app ru...
maxbuffington
Jul 04, 2022Initiate
Your recommendation worked!!!
I’m using iOS 15.5 for my iPhone and iPad.
Thanks!
Jul 05, 2022Guru - Experienced User
Glad it did!
If you mark it solved it might help the next person with the issue as well as it prevents others from trying to fix it
