Ericwright
Nov 22, 2021Initiate
Nighthawk Ax1500 mesh
Just put a new system into my home. I have a NightHawk Mesh 6 wifi AX1500 with 2 satelites. Everything is set up except one satelite is orange and has been since i set it up. why is this one orange? ...
Nov 22, 2021Guru - Experienced User
Orange or amber? there isn't an orange so I'm thinking its amber.
The satellite is amber when its not linking to the router.
If you log into the router, are you able to confirm its connecting to the router?
What firmware is on the satellite?
And on the router?
Have you tried moving it closer to the router and re-syncing it?
- EricwrightNov 22, 2021InitiateYes it’s amber.
When I check the app it hasn’t connected to it.
I had it beside it initially installing the system and it didn’t connect there either.
The satellite does t show a firmware.
To rest can do I just hit sync on the back of the satellite?- plemansNov 22, 2021Guru - Experienced User
should be able to. Here's the guide.
https://kb.netgear.com/000061554/How-do-I-install-my-NETGEAR-Nighthawk-Mesh-WiFi-6-products#To_sync
One thing you can do is hardwire the satellite into the router. That'll lett it use the wired backhaul and you can check the firmware/update it.
- FURRYe38Nov 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
