MFL100
Aug 27, 2022Aspirant
nighthawk ax1800 satellite firmware
My M60 router has updated firmware V1.1.6.124_2.0.5. My satellites have V1.1.6.122 and are not working. When the router update checked for the satellite firmware, it said no updates were available...
MFL100
I only downloaded the MS60 router firmware update (through my browser) and installed it through the router update. I just recently learned that the satellites also have firmware that needs to be updated, and Netgear says there are none available after v...122 for satellites. Of course, when the satellites.don't work, there is no information about their firmware updates on the router web page to tip you off.
Sep 08, 2022Guru - Experienced User
You may need to downgrade the MR back to v.122, then see if you can get the MS to connect long enough to update the MS. MS have there own web pages you can send the v.124 FW too using a web browser:
