Retired_Member's avatar
Retired_Member
Aug 22, 2022
Nighthawk AX3000 can't connect after power goes out and comes back
Every time the power goes out and comes back I'm experiencing the same issue, none of my devices can connect and I need to power off and on the router. This is very annoying especially because I have...
  • Retired_Member's avatar
    Retired_Member
    Aug 24, 2022
    Never mind, found the solution.
    I disconnected the device and threw it in the trash, garbage service should take care of the rest 😂. Google smart mesh is working flawlessly, did a couple of test and everithing just works without any mess. Thank you very much for your time!
    Also whenever I turned on qos the device started diconnecting devices, when I tried to access a connected device from the list by clicking on it the device screen displayed other random device, not the one selected on the list. Just a note for future references.
    Thank you again, have a great day.
