ParadiseSML
May 26, 2022Aspirant
Nighthawk AX3000 Mesh from Costco
I purchased, from Costco, the Netgear Nighthawk WiFi Mesh (AX3000 or MK73). The system works well, but I am in need of adding a third satellite to the system. The only Nighhawk satellites available...
May 27, 2022Guru - Experienced User
Do you need more MS?
The system seems new and thus not sure if any other MS models are compatible.
https://www.netgear.com/support/product/mk73s.aspx
ParadiseSML wrote:
I purchased, from Costco, the Netgear Nighthawk WiFi Mesh (AX3000 or MK73). The system works well, but I am in need of adding a third satellite to the system. The only Nighhawk satellites available are the MS60 (AX1800) and MS80 (AX3600). Which of these satellites is going to work with the MK73? My assumption is the MS60, but cannot find an answer.
- plemansMay 27, 2022Guru - Experienced User
That makes it interesting. The MK70 series is still dual band but has a wider (160hz) 5ghz channel in a 2x2 configuration.
Both the 60 and the 80 series fronthaul is only a 80hz wide and 2x2. But the 80 series has a 3x3 backhaul that's 80hz wide.
That will make compatibility interesting as you can use 60 series satellites with the 80 series router but not the other way around. Wondering if any of the mod's will chime in with compatibility plans for it.
- ParadiseSMLMay 27, 2022Aspirant
The two satellites cover the house well. They also give me coverage at our dock. The reason a 3rd satellite is needed is to access our cameras on the dock. The camera system requires a wired connection, which I can get on a satellite. I've tried a network extender, but to view on your cellphone both cameras and cell have to be on the same network.
- FURRYe38May 28, 2022Guru - Experienced User
If you connected a extender, the extender should be on the same network if it's in extender mode and not creating a separate network.
