Ralphie2
Aug 19, 2021Tutor
Nighthawk AX3600 MK83 Mesh SUCKS!
I purchased the NightHawk Tri-band WiFi6 Mesh system MK84 (an MK83 Mesh system with an additional MS80 satellite). I followed the initial setup instructions but am unable to complete the setup becau...
- Aug 20, 2021
What modem/gateway are you connected to?
A modem/router combo device can cause a double nat and cause issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Ralphie2
Aug 20, 2021Tutor
Thanks FURRY. That was actually how I ended up successfully setting up my previous mesh system . . an Orbi AC1200.
Aug 23, 2021Guru - Experienced User
Enjoy.
