Str8Cracker
Jan 17, 2022Follower
Nighthawk AX3600 vs Orbi RBK-753s
Hi guys, looking to replace my old luma mesh Wi-Fi with either the nighthawk or orbi. I’ve found both with one router and two satellites for $400. Any opinions on which is better in real life? On paper they seem very similar despite the size difference. I do utilize a wired backhaul.
I did some searching and can’t seem to find much comparisons between the two, mostly just each with another manufacture. Thanks for your time!
1 Reply
You might look at the Orbi system.
Kind of depends on your home size and placement of satellites.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
