egmol
Jun 02, 2020Aspirant
Nighthawk C7000 and Orbi Mesh Wifi compatabilitiy
Can I use the Orbi AC3000 Mesh Wifi sysem with my Nighthawk modem/router C7000?
Jun 03, 2020Guru
If you already own the C7000, I wouldn't buy the cm500. I'd use the c7000 in modem only mode and then add the orbi to it.
You have the right idea by running wires. brick does an amazing job of blocking wifi so the more devices you can hardwire, will help.
egmol
Jun 03, 2020Aspirant
Thank you - very helpful!
