JamesterReyburg
Apr 18, 2022Star
Nighthawk M60 Mesh system died(?) Foolishly got a new one. Solid Red Light.
I have had the Nighthawk AX1800 MK62 WiFi Mesh system with 2 satellites for a year or two (who remembers). I've had endless problems with them due to the dual bands, and the need for 2.4 for many hou...
JamesterReyburg
Apr 19, 2022Star
I do have a question: how on earth would I know what firmware is on the satellites? I ask bemusedly, because they are presently nonfunctional. And this process we're doing right now? Is part of the reason I'm so unhappy with this product. Nobody should have to know all of this stuff for it to work. And I've been a "pc guru" to my friends and family since the Windows 3.0! 🙂
Apr 19, 2022Guru - Experienced User
If you factory reset the satellites, their default ip address should be 192.168.1.250. You can hardwire a pc/laptop into them and check their firmware and upgrade it that router as well
