davenakamura
Mar 01, 2022Follower
Nighthawk Mesh 6 Mk3 Router and Satellites Won't Sync
After an internet hang up, I unpowered by cable modem, the Mk 60 mesh router and two satellites. I powered up the modem and once all it's status lights were lit normally, I powered up the router. A...
Mar 01, 2022Guru - Experienced User
Try connecting the satellites hardwired into the router and sync them.
What firmware is on the router?
What firmware is on the satellite.
- Cardinal56Mar 02, 2022Initiate
I had the same issue where two of my three satellites would turn blue. I hardwried them to the router as recommended and it worked a treat. Thank you so much.
